How to get 5.1 on a coaxil cable (spdif) in games
You need a soundcard that outputs it, and a speaker setup that receives it. Then connect the two with a coaxial digital cable. Then as long as your game/player supports it, you are done!
You'll need a sound card that supports either Dolby Digital Live or DTS Connect (or both)
DDL will be limited to a max bitrate (all channels combined) of 640kbps.
DTSC will allow you to have a higher bitrate output (up to 1.5mbps), so you'll get a slightly better sound.
Of course, your receiver also has to support Dolby Digital, or DTS ;)
