How to get audio from XBOX 360 if monitor has speakers but no HDMI?
23 Oct 2011
My title explains it all. Basically the speakers on my new monitor are supposed to be pretty decent (LG), though I have only just ordered it, am wondering how will I get sound from my 360 sent through to the monitor - which cable do I require? Pretty sure the monitor has an analog sound input, so how do I transmit it from the 360 to this? Thanks in advance,= :)
D-Sub: Yes
DVI-D: Yes
Headphone Out: Yes
PC Audio In: Yes
you'll need an Xbox 360 VGA HD AV Cable
http://hardware.teamxbox.com/screenshots/screen-hires/42546/Xbox-360-VGA-HD-AV-Cable/
Then an adapter a bit like this:
Don't get this exact one though because the 2 RCA cables(red and white) won't fit in properly.
Edit: this would be perfect:
