Pull off the cover of the pull handle ( the one you use to close the door ) there you will find 2 large cross head screws.
Unscrew the lock pin.
Pop off the panel, but this will be very tight. the panel sits in a slot in the inner waist rail, you can either lift the panel upwards taking the waist rail with it, or pull the panel out of the waist rail and remove it separatly
