- 7 Aug 2004
Hi all, iv got a DVR2400 surveillence system, when i install it though it stops me accessing task manager for some idiotic reason
even reenabling it in reg edit it wont work after reboot, seems the program overwrites it.
Also theres LOADS of exe files in the program trying to send data from my PC, one's called 'chat' and looks very dodgy.
In a perfect world I want the card to work and use another program to use on my security cam, BUT i CANNOT seem to get the card working only installing the drivers alone
its THE MOST annoying thing ever, any1 got this and how have you got around it ?
The PCI capture card is H1004S video capture card, BT878 chipset, 4x BNC inputs, iv tried using 3rd party but there is no 3rd party driver for BNC input, only composite
even reenabling it in reg edit it wont work after reboot, seems the program overwrites it.Also theres LOADS of exe files in the program trying to send data from my PC, one's called 'chat' and looks very dodgy.
its THE MOST annoying thing ever, any1 got this and how have you got around it ?The PCI capture card is H1004S video capture card, BT878 chipset, 4x BNC inputs, iv tried using 3rd party but there is no 3rd party driver for BNC input, only composite
