How to get incremental counter in SQL2005
11 Feb 2004
Surrey, UK
When using SQL 2000 is was very easy to assign an atrribute to a field which meant each time a new record was added it would increment by 1.
I can't seem to find this in 2005? Any ideas welcome :)
Using Management Studio, you need to set the Identity property to true on the column, and optionally adjust the Identity Seed and Indentity Increment properties.
