How to get lining back inside gloves?
Permabanned
3 Aug 2009
Manchester
Hello guys.
Is it possible to get lining back inside gloves after you've pulled them off?
They are my bike gloves and when I get back home they were a bit damp and as I pulled them off my hand the lining came with my hand and out of the glove.
They are a thinsulate lining.
Is there any techniques to get the lining back inside the gloves and into the fingers?
Cheers
Put the lining on then put your hand into the glove, hold the fingertips and slip your hand out? A guess :)
Impossible to do as the lining is actually attached to the end of the glove.
Maybe I didn't make my self clear enough but the lining isn't seperate from the actual glove. It's attached.
Cheers
This happened to me before with skiing gloves. Absolute nightmare. Just get new (better) gloves tbh.
If you can line the fingers of the inners up to the correct fingers on the outers then using the blunt end of a pen or similar you should be able to tease them back into place.
Good idea. In the end I got fed up though and just cut the lining my self and put it back in that way.
Going to get a new pair next week... Hopefully ones that don't have lining in them!
