so just the base station or a bit of the spray a for inside ?These worked for us. We had ants farming aphids on our rose bush. Not for long though.
what about indoors ?Yeah the bait stations are great. They pick the nastiness up from it and take it back to the nest.
Find a path between outside and inside that they cross. Put bait traps in the path.what about indoors ?
Thanks
Thanks can only be at the door or through air bricksFind a path between outside and inside that they cross. Put bait traps in the path.
My niece is going down tomorrow to clean behind the appliances but will need to get the bait for herAttacking the symptom (poison traps) rather than the cause is pointless.
You need to make sure your kitchen for example, is always really clean, or they will keep comming.
				She cleans every day but can’t pull out appliances so any crumbs get left. Will just need to get family to help moreHaving a property in Spain it's quite simple.
Never leave any food open, even a few grains of sugar on the kitchen counter or a drink spillage not properly cleaned up ... Otherwise you're inviting an invasion.
No food =no ants.
Will write this on anything I put down for themPut a sign up for them:
"No Ants allowed"
Simple...
Thanks for the replyYeah maybe help them with a proper clean by pulling stuff out, then hopefully maintaining top surfaces will be easier.
