How to get Tomb Raider running smooth?
12 Dec 2005
I've just purchased, downloaded and installed Tomb Raider. I set most settings on high, making sure to turn off TressFX, post processing and tesselation however I only seem to be getting about 40fps.
My spec is in sig, I thought I'd be able to get more FPS out of this if I'm honest.
Does anyone else here have a similar PC to myself. How did it run for you?
EDIT: It seems that the preset 'High' puts a few graphical settings to normal and now it seems to be maxed out at 60FPS. Still thought I could run it on higher graphics settings!
Yeah, as said previously Tomb Raider is a very demanding and beautiful game and your 7850 will not quite have the grunt to run everything on top settings at a decent FPS.
Gives me more of a reason to upgrade. :D
Still, looks great on high! And it's getting into one of the best games I've played on PC so far.
yeah i had a 6950 and it ran at around 30 fps pretty much maxed out, it was still playable though, i even had tressfx enabled just on the closups of lara it just went baywatch slow mo - it was kinda atmospheric! now with a 290 i get upwards of 60 fps completly maxed out but on closups of laras hair it still sometimes drops to 35-40 ish! but thats still better than 10-15 fps baywatch mode i was getting on the 6950 - kinda
Great game just wish they worked on the TOMB sections and made them a bit more technical. All the stuff that made Tomb Raider the iconic game it was could have been fleshed out a little in the very short TOMB sections of the game.
Still it is a good game for the rest of the time.
Just make use of the in-game benchmark, toggling settings to see the impact they have. You don't even need to wait for the bench to finish, just memorise the approx framerate you were getting at a couple of points as it pans round.
Good starting points for tweaking any games are settings relating to shadows, dynamic lighting, ambient occlusion and anti-aliasing. Oftentimes simply choosing 'medium' or 'high' is suboptimal because it lowers more settings than you need to, compared to manual tweaking (i.e having loads of stuff on ultra but with a couple of things that really impact framerate turned down).
