- 14 Jun 2011
- Glasgow
Hi all.
I've just insulated my shed with aluminium foil and when I close the door I loose my wifi and data.
On the outside of my house I have a tp link cpe210 set as an access point, nomally wifi in the garden is fine.
I can't run an ethernet cable to the hut.
Putting an extender inside the hut won't work either.
All I can think of is and outdoor aerial connected to a wifi router inside the hut, with the screw off antenna removed.
Does anyone have any ideas? or recommendations?
Many thanks.
Many thanks.
