How to have my PC in another room?
Caporegime
29 Jul 2011
In acme's chair.
Evening all
Building an extension currently and planning all the wiring.
The idea of having my PC in my 'cupboard' along with my server and other items crossed my mind. I could use displayport wall plates for my monitors because they can be up to 50ft in length, but I'm not sure how I'd do USB?
I briefly looked into adding a Thunderbolt card to my PC so I can use an optical Thunderbolt cable and a Thunderbolt hub like LTT used in his house, but it turns out you can't add Thunderbolt to a PC that doesn't already support it because it requires a special header...
Anything further before I give up? :p
Also interested in doing this but came up with the same blockers. I thought I could run wireless USB mouse and keyboard but for other devices it would mean plugging in directly which might be a pain if you have access limitations or want to plug in a USB stick for example.
What sort of DisplayPort wall plates have you seen? I've only looked into HDMI wall plates as I thought DisplayPort ones didn't exist because they're not used on TVs where wall plates for display are more widely used.
