- 12 Feb 2009
- London
So I have a 2010 astra hatch that has a single reverse light which is shocking. You can hardly tell its on most of the time when reversing at night.
I have fitted a led bulb into it but I think it's more of a projector bulb that does not fire it back into the reflector.
I guess I have 2 options. Try find a better bulb or fit a larger reverse light on the bottom of the rear bumper.
Has anyone got any recommendations on a decent bulb that will actually light up the ground behind the car?
Edit- they are h21w bulbs.
