Well i dont know anything about these numbers but hopefully someone on here can have a look and help!
This is after buying a homehub 3 for my "up to 20meg" option 3 package.
This first part is from some test thing i found through BT...
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
4239 Kbps
7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 4239 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :5237 Kbps(DOWN-STREAM), 965 Kbps(UP-STREAM)
IP Profile for your line is - 4620 Kbps
2. Upstream Test: -provides background information.
Upload Speed
754 Kbps
0 Kbps 965 Kbps
>Upload speed achieved during the test was - 754 Kbps
Upstream Rate IP profile on your line is - 965 Kbps
This next part is from inside the hubs page stuff...
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 02:36:08
Downstream: 5.115 Mbps
Upstream: 965.6 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 2.6 dB / 5.9 dB
Line attenuation (Down/Up): 51.1 dB / 32.2 dB
Output power (Down/Up): 18.1 dBm / 12.6 dBm
FEC Events (Down/Up): 865360 / 68
CRC Events (Down/Up): 478 / 33
Thanks for any help or advise people very much appreciated to any who take the time to look through this for me.
Download Speed
4239 Kbps
7150 Kbps
Upload Speed
754 Kbps
0 Kbps 965 Kbps
ADSL Line Status
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
