2 Jun 2013 at 20:21 #1 skronk skronk Associate Joined 30 May 2013 Posts 23 When looking up QVL many do not show memory makers. How does a builder know what is compatible and what is not ? Overclocking not required !! Thanks Skronk
2 Jun 2013 at 20:45 #2 RJC RJC Don Joined 29 May 2005 Posts 29,086 Location Kent It very slim these days to find memory that will not work with your system. Majority of manufacturers as you found out don't keep there QVL list updated to due to the mass of memory options out there and new models coming out.
2 Jun 2013 at 22:29 #3 skronk skronk Associate OP Joined 30 May 2013 Posts 23 RJC said: It very slim these days to find memory that will not work with your system. Majority of manufacturers as you found out don't keep there QVL list updated to due to the mass of memory options out there and new models coming out. Click to expand... Thanks, so if the mobo will handle it then it is worth a try ?
2 Jun 2013 at 22:32 #4 RJC RJC Don Joined 29 May 2005 Posts 29,086 Location Kent skronk said: Thanks, so if the mobo will handle it then it is worth a try ? Click to expand... Yep Belongs your not trying to fit DDR2 into DDR3 slot you be fine
