How to know if it will fit ?
By checking case depth to see if CPU Cooler will fit.
If your motherboard is ATX you need ATX case.
Length of graphics card too.
99% of the cases listed will have this info in the description.
These are the specs, (there just copied from the person I bought it off)
Intel Core i7-2600 3.40 GHz to 3.70 GHz
Gigabyte Z68AP-D3 motherboard SLi ready
Medion high performance Heatsink and Fan with blue LED
2 TB HDD
8 GB DDR3 system Ram
Dual Layer DVD R/W drive
nVidia Geforce GTX560 ti Gigabyte video card with Dual DVI and mini HDMI out
On Board 8 channel surround sound card with Optical SPDIF (toslink) out port
On Board 10/100/1000 Network Card
6 USB 2.0 ports (2 front 4 rear)
2 USB 3.0 ports (2 rear)
2 case fans for extra cooling, with blue LED's
2 Removeable Hard drive bays
Multi card reader
Anybody know what sort of cases I could use ?
First and formost, if this is your first ever PC build/swap. I would suggest you take plenty of photo's of your computer before you take anything out. So you have a reference point incase you actually get stuck.
However PC's are made so you cannot plug the wrong cable/component into a wrong port/socket.
Secondly - take your time with it, do not rush and just enjoy learning.
