How to learn the guitar?
27 Jul 2005
I've had a guitar for ages but never really got round to playing it. I'm quite bored atm so maybe I'll give it a go. What's a good book to get me started? I can do basic chords and stuff but I want to play basic choons etc. Everyone says Good Riddance is really easy for beginners but I tried it and it was hard.
And where do you get those electronic tuner things from? Do they work?
I feel like such a noob.
converse_uprise said:
You can get a tuner from any music shop, or if needs be argos.
What sort of music are you into?
Green Day, Bob Dylan etc. - stuff which is supposedly easy to play on the guitar so its even more annoying that i cant.
tuner i use
Also, if you are serious about it, get some lessons, even if it is only a few.
When i first started i was self teaching for about 6months, with a friend helping me every now and again, as soon as i gota teacher he sorted my technique out, and within the 2 months ive had him i really have noticed a difference!
wonderwall by oasis - worlds easiest song
im self teaching as the guys who i know who have been taught said it was a waste of time, their words not mine
Try and learn as many tabs as possible, for example this site is good. UltimateGuitar.. Definately a great way to learn styles, expand ability and just get in regular practise by learning your fave tracks/songs.
Just try and stick at it, it also helps GREATLY if you can get a tutor, or even just someone to go through a couple of songs with you and explain/show them through thoroughly. Definately speeds up the time taken to pick things up.
EDIT :: Ok if your into Bob Dylan, then 'Born in time' is really quite simple to play with just basic chords (forgetting about the intro..). Here's a link and if you hover over the chords it gives a diagram of how you to play them. :)
The world's easiest song is:
Masters Of War - Bob Dylan.
It is
Am
Then you lift your index finger (can't remember the name of the chord)
then Am again.
Repeat until bored. :p
