How to Lower CPU Voltage?
Permabanned
7 Nov 2006
Nottingham
I have a Abit Fatal1ty F-I90HD ATI Micro ATX Motherboard and the lowest CPU voltage is 1.35v and looking on this forums this seems to be the voltage people are using when overclocked at 3ghz + not stock like mine . Is there Software which can lower the Voltage?
Are you sure that's the lowest voltage you can get from bios, mine goes way lower than that. I've got the same cpu and can get 2.8Ghz on stock volts (1.325V).
