How to make a Snes White again
There are loads of guides on the internet. It is mixing hydrogen peroxide with corn flour to make a paste iirc.
80s and 90s plastic had bromide in it, which is a flame retardant.
This tends to react with UV an turn yellow. Try not to leave any SNES carts on a windowsill!
Not heard of a PS1 turning yellow though!
Its my psone controller, ive bought them all of ebay, the snes isnt that bad apart form one panel.
I cant find a decent guide anywhere.
I'm guessing you could also try re-spraying it. Quite a bit of hassle though I imagine. Unless you fancy some nice custom colour of course :D
just happened to read this in an amiga group just now
hi just incase anyone is thinking tentatively about whitening amiga equipment ...i gave it a go today ...used bblonde 12% peroxide hair blonde stuff from boots ..(bout 1.65 ish ) 3 hours in great sun 1 hr in overcast took out marker pen and minor marks , also soaped and rinsed the keys and cleaned the whole top half and the trapdoor unit ..( not confident bout stripping completely to do base ) results are awesome its like i unboxed it brand new today ...so proud , couldnt believe how simple/available the product was
thought it might be of some use.
