How to make flash content stay in middle of browser
Caporegime
13 May 2003
Warwickshire
Hi all
I'm making my first flash website for my brother-in-law's wedding, and I'm learning fine, but the simple things always seem to be the hardest!
How do I make the flash movie content stay centre justified in the browser no matter what? I have given it a "middle" alignment in Dreamweaver
Code:
id="index" align="middle"
but it still stays hugged to the left side of the screen.
Any ideas?
If it's the only thing on the page, you could put in your stylesheet:
Code:
body { text-align:center; }
and then if you wrap your flash in say
Code:
<div id="flash"></div>
and in your stylesheet put
Code:
div#flash { margin:0 auto;width:widthofyourflashmovieinpx; }
Should do the trick
Thanks very much, but before I saw your solution, I tried inserting a table in the html in Dreamweaver and aligning the table centre, which worked.
Here's phase one if you're interested
http://www.robertandcatherine.site40.net
Going to make an entire flash site with linkage to other pages that the subtitles refer to (haven't figured that out yet!) and hopefully a database showing the people getting married who has bought what from their wedding list, since they don't want to use a department store. That last part should be interesting since I haven't even read a line of PHP yet!
Hi Robbie
Tables aren't really considered good practice for layouts nowadays, you should definitely look at using divs and stylesheets.
Tables are for displaying tabular content - they are not designed to be used for design & layout.
CSS is for layout. You want to be keeping content and style separate (and it also allows you to use a single stylesheet to change the look/feel of multiple pages with the minimum effort)
Code:
Code:
Code:
Should do the trick
Hi, I've tried this and it works perfectly! Thanks!
However can I ask what you mean by "If it's the only thing on the page"? Does that mean that if I add extra html outside the Flash movie I need to define that block and style it also?
Hi Robbie
Yeah it just means that because you set
Code:
everything on the page will center, so if you wanted other stuff aligned differently, you'd need to set say
Code:
div#other_content { margin:0 auto;width:100%;text-align:left; }
to overwrite the body's centering.
