How to make movies?
13 Jan 2005
Hey,
I wanna make a movie on COD? :)
What other software can I use, than Fraps beacuse you can only record for 10 seconds?
Once I the movies recorded, How can I add them together and edit and add text to the movie?
Thanks,
Acutally i didnt read on the the first post a good program to edit footage is vegas video try that out.
bbK said:
isnt that to edit movies not to actually capture footage of games?
Maybe you could try start>all programs>accessories>windows movie maker?
Im sure someone else will know
edit: already said
Thanks, :)
I recoderd me playing in Call of Duty which was save in a demo (/Record ), is there any other way to record you playing in game?
Beacuse you cant edit them with windows media play. :)
I had a quick play around with it, any way to add music?
Thanks for your help so far and quick repsonce.
You can take lots of small movies with the free version of FRAPS and combine them in Windows Media Player
If you buy FRAPS (not a huge amount IIRC) then you can take movies of unlimited length. Bare in mind that it records them without compression - therefore a few minutes long movie can be 300MB
You can use Windows Media Player to shrink and compress them into wmv's (not great but OK and free). Alternatively you can use DivX/XVid/etc
When I made movies I used the tv out on the gfx card then input that into a vcr and recorded the footage, then get a pc card to get the footage back into the pc. To add music etc just get any half decent video editor.
get full version of fraps then :rolleyes:
just use virtualdub to compress it with xvid codec, don't use windows movie maker, uses wmv
