- 5 Sep 2003
- Cardiff Geordie
I have an ASRock '4Core-1333 Full HD' mobo which has dual display outputs onboard - one VGA and one DVI. I'm using a crappy old monitor atm which only has VGA input - any ideas how to make the motherboard output to VGA as default?
I've looked through the BIOS using my other display which has DVI but to no avail. I do see an image on the VGA monitor, but it only flashes up for a second and then disappears.
I assume if I get to an OS via the DVI display and install the onboard display drivers I could tell it to default to VGA, but if I'm ever stuck without my DVI display and it switches back I'm up the creek.....Any ideas??!
