How to measure temps?
28 Dec 2003
Just tried CoreTemp on my new E6850 and it's showing 11C for each core - this can't be right?
Is there another gizmo that will read the correct temps?
TAT won't even run, gives an error on startup.
Need to reinstall Windows really, as it's still the old install from the previous AMD based system so that could well explain TAT not working. Just wanted to check temps were ok and so forth before embarking on the nuke.
check temps in the bios to make sure everything is in order.
Then format FFS! :D
