Perhaps some people may wonder how to merge video clips together when watching them. Actually, this work is quite easy, if there’s a video editor available in your computer. For this case, I’d like to share some effective methods that can finely merge multiple video clips as one file.
Method 1: Use Windows Movie Maker
Windows Movie Maker is a preinstalled program for Windows users. You can search this application in Windows menu searcher. You can do some editing jobs with this tool, such as chop and merge video files as well as add caption and BGM. You can refer the following steps to merge videos.
Step 1: Launch Windows Movie Maker.
Step 2: Add video files in this program in a sequence.
Step 3: Go “Files” > “Save project as” to generate and save video in your disk.
In addition, there’s another software that also does a great job in editing video files.
Method 2: User Video Converter Studio
Video Converter Studio is a professional program for converting and editing media files. With this tool, you can merge any video clips together as you like. Plus, the program also has some practical tools like video downloader, screen and MV Maker. The exact operation steps are as below.
Step 1: Download and launch the program.
Step 2: Add target video files in program.
Step 3: Enable the option “Merge into one file” on interface.
Step 4: Click “Convert” button to get start.
If you need a certain format, you can configure settings in advance. Click “Profile” on main interface then choose a preferred output format on pop-up window is okay.
Wish this post helpful.
