How to monitor vram on 5970??
Permabanned
22 Feb 2010
Hey
How do I see how much VRAM is in use on the 5970 cards.
Running cat 10.7a
I want to monitor the VRAM use during big games to see if it's my ram filling up that stoping my gpus from getting over 60% use
If your using 2x 5970 you aren't going to see full GPU useage except on 2560x res or eyefinity possibly (I notice what looks like an eyefinity setup in the sig). Often the 2nd GPU isn't going to be adding a significant amount (maybe 30-40% at best) over the 1st.
EDIT: Is eyefinity (if thats what your using) even working properly with crossfire yet?
there is no such option
there is for me
EDIT: No matter program doesn't seem to work with newer OS.
If anyone does want to try it program I created ages ago for debugging on XP here but just testing it with Win 7 it seems to be unable to retrieve valid data from the GPU.
