How to mount a vertical PDU to a rack?
27 Sep 2009
I've got a Startech 25U open rack and a 12 way vertical PDU. But I have no idea how to mount it as there's no mounting points? Maybe cable ties?
Normally with a vertical PDU there is a mounting bracket which adapts the 3 slot bit sticking out at either end.
Ah OK, all I have is this
Yeah you need a mounting bracket for each end which adapts that bit with 3 slots. Generally it is better to use a horizontal PDU IMO.
OK, thanks. I wasn't sure which type would be better. To me a horizontal PDU might make more cable clutter and I'd have to bring cables up and down the rack, whereas a vertical PDU I can keep the cables at the same level?
Whatever works for you heh. I won't show you my current setup cabling wise :s
That looks horizontal to me, what's the width/length of it?
Depends how big the rack is, a horizontal one wouldn't have enough slots for a 42/47U rack - note that most kit also has redundant supplies.
12 way usually around 28" IIRC - dunno if there is any difference between the horizontal and vertical ones other than the length and mounting bracket.
My 19" horizontal ones are 6 gang + protection or I think you can get 8 gang without the protection bit.
Yeah it was the mounting bracket on the OPs picture that made it look like a 19" horizontal one.
Yeah AFAIK the only difference is the vertical ones come with a mounting bracket which adapts the bracket on the end - I'm not familiar with the full range of mounting options though.
You'd put a few PDUs in. Also, you can have 12 sockets using C13 rather than UK sockets.
