6 Jul 2008 at 08:31 #1 Slinkie Slinkie Associate Joined 21 Oct 2002 Posts 1,680 Location UK Hi Folks, How do mount/ use .bin .cue files in osx to install software? Thanks Matt
6 Jul 2008 at 10:19 #2 OzyOly OzyOly Soldato Joined 5 Feb 2006 Posts 3,386 Location 15,000ft. Slinkie said: Hi Folks, How do mount/ use .bin .cue files in osx to install software? Thanks Matt Click to expand... Well, I'm not sure about the .cue, but if mac os is like unix, then surely Code: sudo chmod +x *.bin ./*.bin would execute the bin file? As fior Cue, I think the only weay you're going to get at that is by burning it to cd/dvd as an image. Last edited: 6 Jul 2008
7 Jul 2008 at 08:08 #3 kilvano kilvano Associate Joined 28 Nov 2006 Posts 224 Location Vancouver...from Glasgow Roxio Toast will mount either for you I dont think OSX does it.
7 Jul 2008 at 09:42 #4 Doug Doug Soldato Joined 18 Oct 2002 Posts 4,293 Location Newcastle Disk Utility should mount them.
10 Jul 2008 at 10:25 #5 platypus platypus Caporegime Joined 25 Jul 2003 Posts 40,506 Location FR+UK Is there a Daemon Tools style prog for Macs?
10 Jul 2008 at 11:34 #6 Logsi Logsi Soldato Joined 19 Oct 2005 Posts 10,511 Location Kernow Disk Utility does everything. Pretty sure it should do this. No need for any Toast malarky.
