How to move outlook.pst?
8 Aug 2003
Hi,
I know that all the outlook emails are stored in outlook.pst which is somewhere on the C drive. How can you move this file to a seperate partition while outlook continues to use this, if you get what i mean?
Thanks,
Win.
I would not do it like that.
Close down Outlook.
Go to: Control Panel > Mail
Click On: Show Profiles...
Select: Outlook
Click On: Properites then Data Files...
Highlight Personal Folders and click on Settings... then you can change the location of the Outlook.pst
Also the Outlook.pst is here by default: C:\Documents and Settings\<Your Username>\Local Settings\Application Data\Microsoft\Outlook\Outlook.pst
sfx
