How to O/C (OCZ Gold) Memory ?
11 Oct 2005
Derbyshire
I have the OCZ 1GB (2 x 512MB) PC3200 Dual Channel Gold Series BH5 EL-DDR CAS2.0 (OCZ4001024ELDCGE-K) (MY-054-OC)
memory in my computer (in sig) I have managed to O/C my opteron 146 @ 2.7ghz with some easy advice from you guys on air and everything has worked fine for the last 4 weeks.
Just wondering how to OC my memory ? and what i gain from doing so. Then do you just use mem test and SuperPi to check for stability etc ?
Just new to O/C you see and not sure the benefits I gain from O/C my memory. I really dont know where to start, I have searched on here but alas, not found anything of use yet.
thank you
This type runs at 2-2-2-5. Pretty much the lowest and fastest timings available. Unsure if latency timings are stable at 1. Could give it a try!!!!
i know it wil run at 2,2,2,5 but what i dont know is what the 2,2,2,5 relates to so i can try it in my BIOS. what do the 2 for eg relate to settings wise
