9 Nov 2010 at 02:58 #1 builder22 builder22 Soldato Joined 14 Dec 2005 Posts 5,056 router is a linksys WAG354G. when I play COD online it says NAT type is strict what do I change in the settings to "open NAT" ?
9 Nov 2010 at 10:45 #2 yashiro yashiro Soldato Joined 9 Dec 2003 Posts 3,621 Location UK It depends on your router. You could try changing the NAT settings to Endpoint Independant only. Or just put your PC into the DMZ for problem games.
