How To Overclock a GTX 280 via Nvidia Control Panel Only?
23 May 2007
Loughborough
Hi guys, I am currently using my aging 8800 GTX and currently overclock it using nvidia control panel, I can increase the core bus and memory bus via this piece of software.
My question is when my 280 GTX arrives can i overclock it the same way? I have heard people taking about overclocking three things on graphics cards (something to do with shader?) - i'm not really sure on this, but if someone could just confirm if the nvidia control panel is all i need to overclock my card then great ;)
Or is there something i'm missing? cheers guys!
you should have no trouble on the new version
its better than nvidia cp
you can save serveral clocking prfiles too
which is useful for certain games/benches etc
I use Gainward Expertool to overclock those 3 functions on my 8800GTX, works perfectly. When my GTX280 arrives I'll try and use it on that.
