how to overclock GTX........
14 Nov 2012
Chesterfield
I've just installed MSI Afterburner for my MSI GTX660 TwinFrozrIII and would like to know how to balance the overclocking of the card?
Any specific settings to get the balance of power, Mem Speed & core speed?
I would obviously like to avoid damaging the card, BSOD & random resets.
Thanks :D:D
Hi
This guide is maybe a bit Anal at times but the basics are fine. Though for a 670, the principle should be the same.
http://www.overclock.net/t/1265110/the-gtx-670-overclocking-master-guide
Though obviously without voltage adjustment, there is only a limited amount you can do to any Kepler based card.
Have fun.
PS. AB version 2.2.3 does support voltage adjustment for a limited number of MSI cards (680 Lightening and the 670 PE ... not sure about the 660 PE).
