How to Overclock my 6800?
12 Dec 2005
Hello.
Ive recently just unlocked my pipes for my 6800 graphics card.
Alls i want to do now is overclock it, ive read the sticky and i cant quite follow it.
So can some one please supply me with some links/tips for overclocking my 6800 (ive never done it before!)
Thanks
Go into the control panel,you will see a clock frequencies tab,click on that,then select detect max clocks(something like that,can't remember) the card will then tell you what it finds the max clocks to be.Then run 3DMark & check for artifacts.
Hope you understand all that
Rob
