How to plug front panel connections in
5 Apr 2009
West Midlands
My motherboard is a Asus P5KPL-AM. Case is a Coolermaster Elite 333. I think everything is okay, just tried turning on, no luck. I'm hoping that it is because I had no idea whatsoever in how to plug in the cables for the front panel, which includes; Turn on, Turned on LED, Restart, HDD activity, 2 USB's, Hi def audio and, speaker?. Any help please guys. This is a new rig for my mum, and my first real build by myself.
The motherboard is labled were the ports are, the usb have bung in one corner so these are pretty fool proof.
The Power button in the past has never been an issue as this is just a switch, the leds I tend to get the wrong way round they work or they don't, just a case of turning the plug 180deg.
Double check all power connections are in including the 4 pin for cpu power, also CMOS reset works for me sometimes.
Sorry some area's above are not more clear cut but it's a case of checking the manual and board, good luck :)
Got the Power working and everything is okay, loading up XP now. Will plug the rest in later. It was labled yeah, just under the wrong place. Thanks anyway mate. :D
