How to power an Arctic Accelero from the Motherboard?
5 Mar 2012
Hi
I have ordered an Arctic Accelero and understand that it is supplied with a cable that you can use to supply 7V or 12V to the fan by plugging in to a Molex ie the fan RPM is fixed
Is there a cable or plug adapter you can buy which runs from the GPU to the Motherboard GPU 3/4 pin supply so that you can vary the fan RPM via Afterburner or other ?
From what I've read you can power it via your card directly if it supports PWM. Which version of the Accelero have you ordered?
