How to Print life size picture of me on to multiple A4?
7 Nov 2006
Nottingham
Hi , i'm going traveling for a few months and i would like to print a lifesize picture of me on to multiple A4 and stick it on my door so my house mates don't get lonely , Do you know any sites or programs which can do this? I've seen some but for a 6ft Tall image it needs a equally large width which is no good.
thankyou.
Just had a look at Rasturbating and its the same as other programs :(
The amount of paper used in height is connected to amount of paper used in width.
I want about 10 sheets high and 4 sheets wide , but rastorbator only lets you do 10 wide!
IIRC you can make it any number of sheets wide and high :confused:
rasterbator let's you control the orientation of the paper, and the number of sheets used... if you want it to be exactly 4 wide and 10 tall, you're going to need to change the aspect ratio of the picture, and then you'll look fat/thin
if rasterbator is saying it wants the same width as height then your image is in roughly the same ratio as an a4 sheet, if you want to alter that then crop your picture, rasturbate wont stretch your image, you need to get it in the right ratio first
