How to properly remove filler from wall?
12 Dec 2005
I filled some holes in on my bedroom wall a few months ago and didn't get around to sorting them out till today.
I've tried to sand the filler down to get it nice and level with the wall, but sandpaper seems to be doing absolutely nothing to it.
What do I need to do?
Sand harder, wrap the sandpaper round a block and go to town on it. Use some lower grit sandpaper if you aren't already.
Best stuff for sanding filler is sanding mesh. Use with some water in a bucket to clear it if it gets clogged up. It really takes a lot of the effort out of it and does a really good job.
