Support Standard ITX Motherboard(17x17cm), FLEX-Small 1U Power Supply (15*4*8cm), Graphics Card (17*10*4cm), Hard Disk(2x2.5inch SSD, thickness less than 9mm), CPU Cooler(Less than
Ed, no offence, how old are you? You needed to ask the internet, what else would the * mean. What does the multiply key\symbol on your keyboard look like?\
Unless you're asking which number is height, length and width.
