26 Feb 2012 at 16:39 #1 Antineo69 Antineo69 Associate Joined 2 Oct 2007 Posts 289 Location Uttoxeter,Uk hi all, What is best Recover Key program for recover user names and key codes, because my seagate HDD has fail and needed to be sended off to seagate.
26 Feb 2012 at 17:10 #2 asim18 asim18 Soldato Joined 5 Dec 2006 Posts 15,370 http://www.magicaljellybean.com/keyfinder/
26 Feb 2012 at 18:32 #3 Buchanan0204 Buchanan0204 Soldato Joined 10 Jun 2010 Posts 5,158 Location Scotland Not sure if you need to actually be running the OS before it tells you. You may be able to point it at the hard drive.
27 Feb 2012 at 06:49 #4 Deception Deception Soldato Joined 23 Apr 2006 Posts 6,500 Location Nottingham Produkey is a good one: http://www.nirsoft.net/utils/product_cd_key_viewer.html It can also recover the keys from an external HDD, so it good for getting keys off HDD's that you cant boot windows from.
27 Feb 2012 at 10:33 #5 Antineo69 Antineo69 Associate OP Joined 2 Oct 2007 Posts 289 Location Uttoxeter,Uk Cheers to all reply Thank you I will try them out. Nick
