how to remote shut down my pc
The BIOS will have some kind of thermal regulation built in - normally you wouldn't have to manually enable it.
You could always use CoreTemp to do the same job. The beauty being that not only can you set it to shutdown when it reaches a certain temp, you can also have it run a script [say to kill any processes burning the CPU].
