Hi,
Ive got the Antec solo case which has a pin, space, and then a pin for the power led which effectively means its 3 pins.
The EVGA 680i motherboard only has 2 pins for the power led so i guess i need to remove the spacer pin from the power led wire.
Whats the easiest way of doing this?
Thanks!
Thanks!
