Normally the screw cover on the base plate of the handle is pretty straight forward but without removing the handle this one seems kind'a locked in, as the cover is a single piece of metal covering the entire base plate. Any ideas?
I know it looks like it's a painted screw, but it isn't it's just a metal cover - dunno why they've cast it like that +shrug+Isn't the left side screwed in? Or is that the side you're lifting?
What's the keycap, sorry?See if you can pop the white key cap out with a small flat screwdriver. Might then be able to remove the handle.
BUT how do you get it apart!!!I know it looks like it's a painted screw, but it isn't it's just a metal cover - dunno why they've cast it like that +shrug+
