How to remove heatsink from Atom motherboard ?
18 Oct 2002
At home
Hi,
Just bought the Intel Little Falls 2 motherboard and looking into replacing the northbridge heatsink / fan as i've been told it can be very loud.
Looking at various sites like http://www.davewsmith.com/blog/?p=179 thye say to remove the original heatsink.
I have just tried but just doesn't want to budge. It is attached by two hooks and nothing has worked, any ideas ?
Thanks,
It's probably get thermal adhesive on it, not thermal paste/grease.
I'd be tempted to get a razor blade and start working my way in from the corners, giving it a little twist with a flat bladed screwdriver covered with a small bit of cloth to protect the board.
Be slow and gentle, but it'll eventually come off.
As above but make sure you are doing it on a flat surface and have a good grip. One wrong slip and you can easily bash the pliers into the circuit board and damage something
( not that ive ever done that ) *whistles*
:p
On mine all I did was removed the fan and then replaced it with this.
Yes it's a 20mm fan instead of the 10mm one that's installed but I just put it on top of the heatsink instead of in the slot the old one went in. Cools well enough and is very quiet.
thanks, i'm tempted to just stick a huge 80mm fan so it cools the entire board / cpu.
Going to monitor the temp over the next few days first, only got it today :)
Nowhere as noisy as I thought it might be though....
Would it be possible to add different heatsinks? With something like a TRUE you could easily run passive, but the mounting wouldn't work and you'd have to cool the NB as well.
