My engine started running rather badly, misfiring badly, at first I thought it was the ignition coil so I changed that, but that didn't fix it. It turns out there is a load of liquid in the spark plug wells. I believe it is actually screenwash, it looks and smells like it, doesn't look like coolant. Having googled the issue it appears to be a common problem where the screenwash somehow manages to end up in the spark plug wells.
I've googled the best way to remove water from the spark plug wells, but there isn't too much info on that. I don't have many tools and haven't really worked much on cars, so thought I'd ask here.
I'm planning on changing the spark plugs and ignition leads once I have removed all the fluid, hopefully it hasn't done any serious damage...
So what's the best way of removing the liquid?
Car: 2000 mk1 Ford Focus 1.8 petrol.
