mrk1@1 said:nail varnish remover/meths
DanTheMan said:It's a fingerprint of glue anyway so a stanley knife is out of the question. I'll try some nail varnish remover.
You reckon turpentine would work equally as good?
A.N.Other said:Not sure about solvents - may damage any coatings you have on the lens?
Phone your optician and ask would be the best bet, I would have thought.
jezsoup said:Before you do that do you have any coatings on your lense?
Pinter75 said:You can get loctite glue remover from most hardware shops. It removes super glue easy peasy.
SpeedFreak said:From an expert who runs his own glasses manufacturing business (as of this month) I will say that acetone is best for removing it from a glass lens followed by meths.
mrk1@1 said:I see your point, so whats your companies vision set out to achieve?
Saves on beerLe_Petit_Lapin said:Sandpaper*.
*Warning: Might result in blurred vision.
