How to remove T-cut?
6 Jan 2006
Newcastle upon Tyne
Further to my recent threads re removing scrathes and using some t-cut on them. Now Im left with a bit of a chalky/film wing despite having washed it twice straight after t-cutting it.
What should I use to remove it?
Thanks
I buffed it off by hand then washed it twice. But it still has a bit of a greasey look to the panel in direct sunlight?
Ok, not sure what you mean though. When I've used it there has been no greasy look to the car, but I've always used T-Cut then applied lots of waxes etc. to seal the paint again.
After using T-CUT, I always then polish the car with a half-decent polish (AutoGlym SRP will do), then re-wax.
Sounds like it wasn't buffed off completely, and has dried on. T-Cut or any polish should get it off, just use make sure you buff it off completely ;)
Edit: Or are you talking about white marks on the plastic trim?
Sounds like you left some behind and it's scorched the paint. T-cut the area again and seal the surface with some good wax this time.
