How to report a problem with the forums ?
20 May 2010
World
Anyone know how to report a technical problem with OCuk forums ?
Specifically it is to do with signatures
The signature preview option does not work properly , when you preview
your signature it looks one way and when you see it in a forum post
it is different.
How do I go about reporting this ?
EDIT:
This is how it looks in preview
oh well , I guess then I cant get shouted at for having too much in my sig then , if the preview is broken
Except for the fact that you have just stated that your signature is to big
so you are aware there is a problem with your sig. So the Mod's have every
right to remove your sig since you stated you are aware of it, when you could
just highlight all the text in the sig and reduce the size which will bring it in line
with what it should be.
My sig is not too big it fits perfectly within preview .........
Ok , so we know there is a problem with the Sig code
Methinks it must have a set char length that then inserts carriage return at that point
BUT
The preview function of the sig bit doesnt have this limitation
Is there any chance this could be looked at by the web dev folks that look after OCuk site ?
