basically, i faffed about with the syncing (had an offline version, then got rid, then put it on again, yada yada yada) and the result is that now when looking at my idisk about half the folders are aliases to a previous offline sync (called myusername-1)...
this bothered me (i know it shouldn't but hey) so i set it to not have an offline copy, deleted the old one, then restarted (to try and reset things) then upon re-creating the offline idisk the aliases are all still in place...
anyone know how i can fully reset the idisk? doesn't matter if i loose anything on it just wanted it all new a fresh and synced properly with its own folders not aliases...
any ideas?
any ideas?
- thanks all anyway
