how to restore folder/files with very strange letters (picture)
29 Jul 2003
got a pen drive with list of very strange file names.
how to restore them?
Looks like the files might have been originally in another alphabet (Japanese, Russian etc) that your system is not set up to display.
You could try installing the extra language support in Windows, but it is possible the file names have been permanently amended.
Problem with that is unless you know which alphabet it originally used, you could end up installing many which could lead to issues later if not configured correctly.
Alternatively, there could have been some sort of security encoding/compression done on the files to stop them being accessible. If that is the case, without the original encoder, it would be difficult to decode.
Given the dates on those folders it looks like they've become corrupted, have a google for usb file recovery software and see if they can pull anything useful off it.
Those are corrupted folders/files. You might get some luck with some USB recovery software. I hope the user has a backup of those files :(
Chkdsk may help you out here, but it also may make things worse. First I'd try getdataback or maybe photorec/testdisk.
