12 Nov 2009 at 20:37 #1 fozzybear fozzybear Soldato Joined 27 Mar 2004 Posts 7,653 Location Manchester Probably a simple answer. I've just enlarged the font using Ctrl and scroll wheel and am just wondering how I can tell what was the default font size before. Cheers.
12 Nov 2009 at 20:41 #3 fozzybear fozzybear Soldato OP Joined 27 Mar 2004 Posts 7,653 Location Manchester doggs said: Ctrl + 0 Click to expand... That seems to work. Is that just in firefox or does it do the same in IE? Thanks for that.
12 Nov 2009 at 20:44 #4 doggs doggs Associate Joined 27 Jul 2009 Posts 429 Location UK Works in lots of applications. Also Ctrl + (increase size) Ctrl - (decrease size) Last edited: 12 Nov 2009
