Had this posted in the Overclocking and cooling section thought it might help some people in this section so here it is
okay made a start on the 2d clocks managed to drop my 19-20 degrees from idle was 65 now its down to a cool 45 this is how
1st off you'll need to download ati tray tool link below as this version will let you change the voltages and memory clocks no problem
http://downloads.guru3d.com/download.php?det=733
2nd once installed set the program to run as an administator and give it UAC conformation then go down to to tray right click on ati tray tool on your task bar go to hardware > overclocking settings
3rd you'll want to have gpu-z just to check it against but in the overclocking section you'll want to change the following settings in this order
[Voltages] from 1.263v - 1.143v (i tried 1.083v but my pc kept crashing on start up)
[Core speed] 500mhz - 450mhz
[Memory speed] at the top where it says values there will be a little box called show as DRR check this box and change the setting from 2880-900 which is effectivly 225mhz vs the original 900mhz
4th save this as a profile called 2d clocks and tick the 'load selected profile at startup' and save
5th in the overclocking opition there will be another tab called 'fan' go into this and this is manly down to user prefence but if your not bothered about the heat my card with the CCC auto fan was idling at 63 at only 3%-4%fan speed but the settings i've used are
temp fan speed%
40 20
50 25
60 30
70 35
80 42
85 50
90 80
100 90
Thats it for the 2d clocks now
now to set your 3d clocks and squeeze some more perfomance out off your card
1st go back to the Hardware > overclocking settings and set voltage to 1.268v and download fur mark and keep increaseing the core settings from default by 10mhz and running furmark to test for stabability in till it becomes unstable
2nd repaet above with the memory speed till you get your highest stable speeds
3rd un tick the 'load selected profile at startup' and save this prfolie as your 3d clocks
4th close the overlocing window and go back to Hardware > Auto overclocking there will be a little box named 'enable auto 2d/3d overclocking' tick the box and load the apropriate profile for each setting hopefully this should save you about 40w power draw in idle and will run a lot cooler mine has droped a full 20 degrees @ 20% fan speed
hope this guide has helped
temp fan speed%
40 20
50 25
60 30
70 35
80 42
85 50
90 80
100 90
