How to secure v.small network?
6 Jan 2006
Newcastle upon Tyne
Wasn't sure if this would have been better in the Windows sub forum but thought the collective minds here may be more suited to a business solution...
I have a very small network, 4 computers, NAS drive and a network printer which are all hard wired to a small switch which is connected to a Draytek Vigor 2920n.
Ive just had Microsoft Security Essentials pick up a trojan on one of the computers that the apprentice uses which I can only presume has come from a Facebook or Twitter link or similar.
Weve only ever had one problem in the past which was actually on my computer(!) but Im wondering if there is some things I should be looking at to help safeguard the network. I appreciate its all down to the user but short of blocking facebook etc is there anything else to consider? To be fair, blocking Facebook wouldnt be an issue but I dont mind them using it on their lunch.
Honestly, for that size network I'd just ensure that:
- You have a good security suite installed and up to date on each PC (Mcaffe, Kaspersky etc.) with AV, Firewall, HIPS etc.
- Unless you have a requirement, ensure users are not local admins and run with UAC
- Take regular backups of your data and store it off site
- Educate your users: Tell them that you can get malicious tools installed from FB, torrents, downloads etc. This is the most important bit and will win most of your battles through 'training'
4 people is small enough to just manage in this manner, I don't think you need to over-complicate it
- GP
Remove local admin rights where possible from users, though some crummy 3rd party software will ask for admin rights (grrr).
You could also look at using a tool like CryptoPrevent to lock down programs running from AppData.
Thanks for the responses, Ive had a look at Kasperky and they offer a small business solution for upto 5 pcs and 1 server here which looks like it will do the job or is there something better? We dont have a server, just a NAS so will this wrk fine without the server?
Unfortunately I cant remove local admin rights as some of our software wont load when you do this.
Will look at CyptoPrevent now as Ive never heard of it
CryptoPrevent is a useful little tool. It helps to stop ransomware viruses like Cryptolocker. As far as backups go, make sure they're offsite (even if it's just a bunch of external HDDs). Somebody somehow managed to infect one of our file servers with a Crypto Locker copycat last year. The offsite backup was the only way to restore the affected files.
